TwinTurbo.NET: Nissan 300ZX forum - Re: NA vs TT Power Steering pump bracket
Subject Re: NA vs TT Power Steering pump bracket
Posted by Rob260 on October 19, 2017 at 8:00 PM
  This message has been viewed 688 times.
In Reply To NA vs TT Power Steering pump bracket posted by Zbullet on October 18, 2017 at 09:54 PM
Message You’ll need four m8x55mm bolts to fit the NA power steering pump bracket.
The belts are the same length however NA has three ribs and TT has four. If you already have a TT belt ready to go there is nothing wrong with cutting a rib off it.
You cannot use a TT four rib pulley on an NA power steering pump without causing misalignment of the belt.
