TwinTurbo.NET: Nissan 300ZX forum - Re: Possible that the clutch is not fully disengaging?
Subject Re: Possible that the clutch is not fully disengaging?
Posted by Felkhar on October 19, 2017 at 5:06 PM
  This message has been viewed 342 times.
In Reply To Possible that the clutch is not fully disengaging? posted by -Grimm- on October 19, 2017 at 04:29 PM
Message Are you talking about trying to wiggle it in gear? I'll see when I drive to work 2mrw. Also, this happened today doing a pull from 1st to 2nd gear. It was the worst case I have had with this situation. I smelt alot of clutch and not it is grinding alittle bit going from 3rd to 4th...winter is coming, and is like to remedy the situation while it is I'm the garage. You think this may be a syncro issue, or more of a clutch issue? I have also heard of the shift plates causing the problem, but I am unsure. Thanks for the response!
