TwinTurbo.NET: Nissan 300ZX forum - Hard to shift at high rpm
Subject Hard to shift at high rpm
Posted by Felkhar on October 19, 2017 at 2:05 PM
  This message has been viewed 404 times.
Message Hey guys,
I was hoping you guys would have some suggestions for me with a problem. My 96 Z is really hard to shift at high rpms some times. 1st to 2nd 2nd to 3rd 3rd to 4th. I'll try to shift alittle before redline and will miss the gear because I can't get the shifter to go into gear. Sometimes you can "force it" in, but most of the time you have to back off and attempt the shift again. I have a year old JWT clutch with their lightweight fly wheel. I replaced the throw out bearing and all that. Only thing I didn't use from kit was the ss clutch line. I also adjusted the clutch per the tech write up on the forums. I'm using redline tranny oil, and I change that every spring. Also, it dpsnt look like my slave cylinder needs rebuilt and i am runnjng a Z1 short throw shifter, so the shifter bushings wouldn't be the problem. Just looking for some suggestions. Thanks!
