TwinTurbo.NET: Nissan 300ZX forum - You can just use the N/a pump, belt and pulley combo
Subject You can just use the N/a pump, belt and pulley combo
Posted by Aaronw on October 19, 2017 at 7:30 AM
  This message has been viewed 402 times.
In Reply To NA vs TT Power Steering pump bracket posted by Zbullet on October 18, 2017 at 09:54 PM
Message on the TT crank, it will just use one less rib on the crank. If you plan to switch the PS pulley over to TT. (I don’t know that it would line up, never done it myself.) but the belts are the same length, the only difference is one is a 3 rib and the other is a 4 rib. K03 and K04. As for the valve covers I just tap them and install pipe pugs.
