TwinTurbo.NET: Nissan 300ZX forum - So I bypassed the turbo coolant lines.
Subject So I bypassed the turbo coolant lines.
Posted by Zluster on October 06, 2017 at 12:26 AM
  This message has been viewed 441 times.
In Reply To White smoke from exhaust: posted by Zluster on October 04, 2017 at 10:29 PM
Message Disconnected and plugged the lines, so some water was still sitting in there, and then went for a short drive. Still plenty of smoke.
So the only other source has to be heads/gaskets.
I think next ill do a leakdown check on all cylinders at 100 psi when cold, then warm it up to smoking and do it again and see if there is anything different.
I think I'll also pull the exhaust and see if the downpipe on one side seems worse, from the tailpipe it seems even, but it might be getting mixed enough that I cannot tell a side that is better or worse.
I did pressurize the coolant system when hot and cold with a tester to see if I could tell where any leak would occur, I could not tell anything.
