TwinTurbo.NET: Nissan 300ZX forum - Oil pump replacement
Subject Oil pump replacement
Posted by infoschumi on October 03, 2017 at 4:49 PM
  This message has been viewed 504 times.
Message Many thanks to ZXoltan for sending me a replacement oil pump !!! He sent it all the way to Europe,I don't have words to thank him ! Pump arrived in my country even faster than the oil pump gasket I ordered from Z1.
I read everywhere that it's very hard to drop the oil pan,but after I took a look at the FSM and under the car,it looks pretty easy.Just remove oil filter holder,a few suspension member bolts and loosen a few others,hoist the engine,remove engine mount bolts and drop the suspension frame/member or how it's called.I got two questions.Am I supposed to just drop the frame a little and the oil pan will be removed trough the space created?Second question is how can I hoist the engine if I have the plenum removed?I can't see anything to hang the engine except the upper timing belt idler bolt.
