TwinTurbo.NET: Nissan 300ZX forum - Starters can spin but still not crank over the engine
Subject Starters can spin but still not crank over the engine
Posted by Josef(Houston) on September 15, 2017 at 7:03 AM
  This message has been viewed 357 times.
In Reply To car wont even crank posted by aztec300z on September 14, 2017 at 11:48 PM
Message If the piston does not pop out and spin then its the starter:
How to Test Your Car's Starter and Solenoid Assembly:
https://www.youtube.com/watch?v=6x2hIOtBfzE
If starter is good, you need to make sure the flywheel teeth are good. Take off the starter and check the teeth on the flywheel in the transmission opening
src=http://i141.photobucket.com/albums/r70/josefweber/photo1
2-1-1.jpg>
