TwinTurbo.NET: Nissan 300ZX forum - It is
Subject It is
Posted by EngineerLV on September 12, 2017 at 8:33 PM
  This message has been viewed 605 times.
In Reply To I think he's saying the gasket is smaller than the MSP port (n/m) posted by ZXoltan on September 12, 2017 at 04:14 PM
Message Thats why you bolt it together and grind it out with a dremel, the manifold will work as a router guide. With a small bit the manifold will stop and guide the cutting bit. I use wood carving rotory bits and a die grinder, works good on exhaust gasket and for grinding aluminum. DRILLPRO 6PCS 1/4'' 6mm Rotary Burr Set, Shank Engraving Bit Cutter, Burr Wood Carving Rotary Tools - Milling Cutter Hss Carbide Cutter Rotary File Set https://www.amazon.com/dp/B01FW4XILG/ref=cm_sw_r_cp_api_.NiUzb7A12P2C
