TwinTurbo.NET: Nissan 300ZX forum - Need advice on 5 Speed Swap + Engine Room Harness Question
Subject Need advice on 5 Speed Swap + Engine Room Harness Question
Posted by Polish on September 03, 2017 at 5:31 PM
  This message has been viewed 248 times.
Message The previous owner of my Z did a 5speed swap. He modified the engine room harness in several locations. One unrelated modification to the 5speed swap was the addition of an aftermarket amp, and he hooked it up to the fuse box that is usually next to the battery. However, he also tucked that fusebox away into the fenderwell. I have the engine room harness from my old M/T 94TT. Would it be compatible with the 94 A/T Dash harness that is installed in the car? If so, I am thinking I could replace the 94 A/T Engine Room Harness with my clean M/T version, but not positive this would cause any problems for me.
Would installing the engine room harness be worth the trouble? Anyone have any thoughts? Here are the photos of the modifications to the engine room harness:
Also, I assume this is related to the reverse lights?
  • Need advice on 5 Speed Swap + Engine Room Harness Question - Polish 17:31:16 09/03/17
