TwinTurbo.NET: Nissan 300ZX forum - Re: If Phillips + gets mangeled I have used vice grips in a >>
Subject Re: If Phillips + gets mangeled I have used vice grips in a >>
Posted by frustrated on August 27, 2017 at 8:11 PM
  This message has been viewed 472 times.
In Reply To If Phillips + gets mangeled I have used vice grips in a >> posted by ZUL8TR on August 24, 2017 at 04:17 AM
Message thanks for the tips all. I was working on vehicle yesterday and everything out of the way to pull the collector plenum. Removed 7 (6 long and 1 short bolt) and to pull it and my info shows 10 bolts.
Anyone know for sure how many bolts hold that plenum on?
Also when you pull that plenum can you leave the throttle body on (less the cables). Not sure if there is a bolt hiding under it.
when one gets the bolts out should the collector lift out easy?
