TwinTurbo.NET: Nissan 300ZX forum - High line is 205. I have bypassed the hi-lo
Subject High line is 205. I have bypassed the hi-lo
Posted by JMartz on August 23, 2017 at 6:53 AM
  This message has been viewed 468 times.
In Reply To Is your electric fan turning on? posted by puchy on August 21, 2017 at 01:16 PM
Message switch on the receiver/dryer to test. Not sure what cover that is. Key item to diagnose is rapid clutch cycling. Computer is turning off power to relay due to some input. Cycling correlates with signal on pin 42, the TCA. Bypassing the TCA still did not improve things much.
Air flow blending doors, coolant valve to internal hot radiator (heater core), occlusion of evaporator and a failing evaporator temperature sensor (TCA) must be involved. No doubt in my mind that the problem is inside the air boxes.
