TwinTurbo.NET: Nissan 300ZX forum - Leaking brake fluid under driver side? Master cylinder?
Subject Leaking brake fluid under driver side? Master cylinder?
Posted by nissubaru on August 21, 2017 at 9:56 AM
  This message has been viewed 609 times.
Message Brakes were kinda weak, but the pedal was not mushy. So I rebuilt all 4 calipers and replaced all the brake lines with stainless ones. Just got around to putting them on and went to bleed them with speed bleeders. Was just trying to purge the whole system mainly so I was just going to town pumping the brakes, started with the passenger side rear, then the driver side rear.
When I went to do the passenger side front is when I noticed I wasn't getting any more fluid out. Instead I was just dripping fluid out the bottom of my car under the drivers side by the pedals.
My initial thought was that it was the top black hose and that was part of the brake line routing to the rear of the car but after digging some more I'm starting to think it's leaking from the master cylinder.
Does that sound likely?
