TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Main bearing grades. Am I in trouble?
Subject Re: Re: Main bearing grades. Am I in trouble?
Posted by brian913 on August 14, 2017 at 5:30 PM
  This message has been viewed 596 times.
In Reply To Re: Main bearing grades. Am I in trouble? posted by Dallas DamonZ on August 11, 2017 at 03:42 PM
Message I had an 8 on my very front main (5 on the crank and 3 on the block). With some research I came to believe that the later engines had an oversize bearing on the front to aid in reliability. I found a chart somewhere that gave some selections (didn't have an 8) but with some effort and some relatively expensive tools (bore gauge and mic) I determined that the bearing was within specs. I did replace all of the other bearings on the crank and am using a TT oil pump and the pressure is really good. Apparently there exists aftermarket replacement bearing if needed. I also found that you could possible shim the bearing with some regular aluminum foil on the half that does not have the oil holes.
