TwinTurbo.NET: Nissan 300ZX forum - Re: Steering rack U Joint replacement tips or writeup anywhere?
Subject Re: Steering rack U Joint replacement tips or writeup anywhere?
Posted by Dallas DamonZ on August 09, 2017 at 11:47 PM
  This message has been viewed 1527 times.
In Reply To Steering rack U Joint replacement tips or writeup anywhere? posted by Poom (Pittsburgh) on August 09, 2017 at 08:51 PM
Message It's part of the engine pull TECH page. Simple stuff:
11. Disconnect Steering (not required, but can make things easier)
Unbolt the steering u-joints, remove both bolts (2 x12 mm)
Slide joints upward to come off steering rack
Make sure not to move plastic indexing piece on lower splines
Since you're replacing the U-Joint. I'd find some way to index the steering column so you get everything lined up the same. I recall the plastic indexer is on the rack and typically that's the end you would pull free to disconnect the column from the rack.
Later
Click here to e-mail me! Click here for Twin Turbo Zs of Dallas!
When was the last time you *really* did something with your Z to call
yourself a Z enthusiast?
Member #1 PETZ
