TwinTurbo.NET: Nissan 300ZX forum - Re: So if you jump the horn relay to ground, it works
Potacka
on August 07, 2017 at 11:32 AM
posted by -Grimm-
on August 07, 2017 at 10:25 AM
If I ground the pins at the clock spring to airbag harness connector i cannot get the horns(and/or relay) to fire. When pressing the horn button I read continuity at the relay socket.
Horn relay not pulling in Previous thread locked
Potacka
11:54:54 08/04/17
This is a rare issue but can happen. If the line running
jzack
20:38:27 08/04/17
Re: This is a rare issue but can happen. If the line running
Potacka
14:00:07 08/06/17
-Grimm-
10:25:00 08/07/17
Re: So if you jump the horn relay to ground, it works -
Potacka
11:32:21 08/07/17
Sounds like the relay coil is shot or the contact is
MixManMash
23:11:27 08/07/17
Re: Sounds like the relay coil is shot or the contact is
Potacka
23:24:26 08/07/17
Re: Re: Sounds like the relay coil is shot or the contact is
Potacka
23:25:33 08/07/17
Anyone else have any ideas?
Potacka
10:40:19 08/09/17
Use a jumper wire to jump from your horn button to
-Grimm-
11:24:12 08/11/17
Re: Use a jumper wire to jump from your horn button to
Potacka
12:48:17 08/11/17
