TwinTurbo.NET: Nissan 300ZX forum - Sounds exactly like the issue I had. Slow down or
Subject Sounds exactly like the issue I had. Slow down or
Posted by SammybTT(TN) on August 03, 2017 at 12:35 PM
  This message has been viewed 572 times.
In Reply To Re: Re: Did you drive it at all, or just start it and rev it? posted by blackemeraldz32 on August 01, 2017 at 09:27 AM
Message stop and the smoke would roll out. As you mentioned this was due to the turbo. I had already performed the PCV delete so only other possibility for me was the turbos -- ended up being shaft play on the passenger side turbo. You can remove the test pipe and see if there is oil in the down pipes and work upward toward the engine, at least that is what I did. If you replace the turbos I recommend a ball bearing turbo of choice
