TwinTurbo.NET: Nissan 300ZX forum - Re: Sorry, forgot to add. If you provide a ground path using a
Subject Re: Sorry, forgot to add. If you provide a ground path using a
Posted by Potacka on July 27, 2017 at 11:05 AM
  This message has been viewed 500 times.
In Reply To Sorry, forgot to add. If you provide a ground path using a posted by jzack on July 27, 2017 at 06:02 AM
Message Problem is new, no accidents I haven't been doing any work on the car. Other than the following: few months ago the horn fuse blew, I replaced the clock spring horn worked for a short time. I assumed it was another bad clock spring and replaced it again however when I tried horn it didn't work and the fuse hadn't blown. Swapped the clock spring back still nothing. I get continuity thu the clock spring (both of them). The horn buttons test good and like I said I'm getting voltage at the relay socket when the horn button is pressed.
I will try your suggestions and report back.
Adam
