TwinTurbo.NET: Nissan 300ZX forum - Sorry, forgot to add. If you provide a ground path using a
Subject Sorry, forgot to add. If you provide a ground path using a
Posted by jzack on July 27, 2017 at 6:02 AM
  This message has been viewed 463 times.
In Reply To Relay having 12v makes no difference since the horn buttons posted by jzack on July 27, 2017 at 05:52 AM
Message jumper at the steering column connector and hear no horn sound. Put a meter on that line and see if you get 12 volts (11.6 or whatever the battery is at). If you do that tells you the wire connection to relay is good and the issue may be with the horns or the relay wiring connection to horns (i.e., engine bay harness).
