TwinTurbo.NET: Nissan 300ZX forum - Relay having 12v makes no difference since the horn buttons
Subject Relay having 12v makes no difference since the horn buttons
Posted by jzack on July 27, 2017 at 5:52 AM
  This message has been viewed 504 times.
In Reply To Re: The first thing I'd do is peek behind the dash around the posted by Potacka on July 26, 2017 at 11:44 AM
Message provide the ground path. That's why I'd try getting the horns to sound using a jumper via the connector that's just before the steering column (I just don't recall if key has to be ON for horns to work, don't think so but look at the wiring diagram).
You'll rule out the engine to cabin wiring harness as the issue. It's very possible the ground connection to the steering wheel is the issue too - but given both the horn buttons and steering wheel ground both pass thru slip a ring connector that's a common thread for failure.
Did this issue just start happening or was an accident or other car work involved???
