TwinTurbo.NET: Nissan 300ZX forum - Sounds like a belt issue
Subject Sounds like a belt issue
Posted by Mike Riddle on July 25, 2017 at 9:04 AM
  This message has been viewed 451 times.
In Reply To Engine noise posted by irdhp78 on July 23, 2017 at 03:05 PM
Message I had belt chirp that went away with belt dressing. Mine was caused by a small coolant leak from a loose radiator hose clamp dripping on the belts. If you find out it is a belt and it happened to start out of the blue, you might want to double check if anything caused it other than wear and tear.
