TwinTurbo.NET: Nissan 300ZX forum - A battery cabling issue should be checked too. Check the
Subject A battery cabling issue should be checked too. Check the
Posted by jzack on July 20, 2017 at 9:07 PM
  This message has been viewed 537 times.
In Reply To My ZX Won't Turn On With Key posted by Adam393 on July 20, 2017 at 01:16 PM
Message ground cable where it fastens to the firewall behind the battery post. The cable is known to frey at that location since it bends. Not enough current flow is would be an issue for the starter.
Any corrosion present on the battery terminals? Never a bad idea if not done in a while to remove the battery post wire clamps and clean both them and the battery posts.
