TwinTurbo.NET: Nissan 300ZX forum - r12 is a far better refrigerant than r134a.
Subject r12 is a far better refrigerant than r134a.
Posted by JMartz on July 11, 2017 at 12:50 PM
  This message has been viewed 545 times.
In Reply To I have an old R12 and it cools well, even when stopped. posted by MixManMash on July 09, 2017 at 09:53 PM
Message On compression it heats up less, about 100 degrees less, hence the less efficient condensers in pre 1994 cars. Upon expansion both drop about the same; but the actual temperature when expanding in the evaporator is dependent on its temperature prior to expansion. Its delta drop is fixed, reason cooling compressed refrigerant in the condenser is imperative for good cooling.
