TwinTurbo.NET: Nissan 300ZX forum - For numerious cars I've used some 180 grit or so sandpaper
jzack
on July 04, 2017 at 12:52 PM
How do you Recondition Al Coolant Water Outlet Pipe?
posted by OverZealous (CT)
on July 03, 2017 at 11:22 AM
to clean up the hose mating surface. It deals with minor oxidation/corrosion as well. Always do by hand since power toal sanding could lead to uneven areas.
OverZealous (CT)
11:22:19 07/03/17
I'm not sure there is much you can do about the pitting.
MixManMash
12:43:44 07/03/17
If your rubber hoses are old and hard that
doug8867
13:38:57 07/03/17
For numerious cars I've used some 180 grit or so sandpaper -
jzack
12:52:55 07/04/17
Cut off the pitted part where the hose sits then TIG on new
xpwarrior
19:44:32 07/04/17
