TwinTurbo.NET: Nissan 300ZX forum - Re: 1st plenum pull = half way complete
Subject Re: 1st plenum pull = half way complete
Posted by Bigmatthew86 on July 01, 2017 at 4:09 PM
  This message has been viewed 485 times.
In Reply To 1st plenum pull = half way complete posted by Bigmatthew86 on June 30, 2017 at 08:09 AM
Message I got as much done today as I could. Passenger side valve covers which were obviously leaking. Changed all the coolant lines I could & completed the coolant bypass. Used the spring clamps from under the plenum instead of the cheap screw clamps they used when the swap was done. Replaced all the vacuum lines I could & installed new clamps. Tightened everything I could reach. It was all needed as everything was well past its service life. Car seemed to run well before so fingers crossed it still does after all this.
