TwinTurbo.NET: Nissan 300ZX forum - Eliminating fade of oem brakes .....
Subject Eliminating fade of oem brakes .....
Posted by zx299 on June 30, 2017 at 9:24 PM
  This message has been viewed 475 times.
In Reply To Re: Re: Mass does help dissipate heat. posted by Bigmatthew86 on June 30, 2017 at 08:53 AM
Message I used to suffer brake fade from heat build up with the oem brake setup when I was peddling through the twisty stuff in the mountains. The distance between one hairpin bend and the next was not long enough to allow the rotors to dissipate enough heat.
I went to 324mm rotors, SS braided brake lines, M/cylinder brace, new pads and Motul RBF600 fluid and that eliminated any sign of brake fade as well as providing an improvement in overall braking. It was one of the best 'bang for buck' mods I have done
"If you own a 300zx, you don't have time for a hobby"
"If you own more than one 300zx, you don't have time for a life"
