TwinTurbo.NET: Nissan 300ZX forum - depends on their condition. Remove the plastic shield>>
Subject depends on their condition. Remove the plastic shield>>
Posted by ZUL8TR on June 30, 2017 at 7:17 AM
  This message has been viewed 388 times.
In Reply To Re: To get the brakes to work the lines need to be free flowing> posted by Mad_Skids on June 30, 2017 at 12:35 AM
Message and post a pic of how the lines are crushed. Then it can be seen if straightening is doable without cracking them in the process. Easier to do that 1st than replace the lines which is $$$ and labor.
Jacks are ok for changing tires that is why they were put in the car. Get some ramps rather that jacking to inspect underside and do work there. They make ramps with a lower slope lead section so the low front Z can get on the ramp. If you ramp it put emergency brake on and put in gear or park and chock the rear wheels for Xtra security. Driving up ramps with a manual requires some caution so you don't over shoot the ramp.
ZUL8TR
