TwinTurbo.NET: Nissan 300ZX forum - Oh ok. Not sure if that hole is there then...
dTb
on June 29, 2017 at 9:02 PM
Is it the hole opposite the indexing pin for the gear?
posted by nelso419
on June 29, 2017 at 08:02 PM
I would assume it would be but i dont know if that hole exists for the exhaust cams... anyways, its directly behind the cam seal when you pull it out... its about .08" in diameter going into the head.
New seals leaking?
nelso419
21:34:24 06/27/17
Did you check the gear itself?
Woody75 (Denver)
22:28:31 06/27/17
Re: Did you check the gear itself?
nelso419
07:58:10 06/28/17
Re: Re: Did you check the gear itself?
LitlElvis
11:30:52 06/28/17
Yeah I just tried mine, they're all solid
nelso419
11:56:23 06/28/17
nelso419
11:23:49 06/28/17
Was there oil pooled in the timing cover?
Tanley (ATL)
21:55:37 06/28/17
Re: Was there oil pooled in the timing cover?
nelso419
10:10:14 06/29/17
The seals don't really see direct oil pressure
Tanley (ATL)
13:46:32 06/29/17
Yeah I oiled them when installing. (n/m)
nelso419
18:29:44 06/29/17
Last thing I can think of is put it back together,
Tanley (ATL)
18:50:20 06/29/17
I had a similar problem a few days ago...
dTb
19:05:02 06/29/17
nelso419
20:02:16 06/29/17
Oh ok. Not sure if that hole is there then... -
dTb
21:02:22 06/29/17
Re: Oh ok. Not sure if that hole is there then...
nelso419
21:20:04 06/29/17
up to you. that puller is twice the cost of a seal and
dTb
22:03:44 06/29/17
I just pulled my seals and yes my 96 does have the holes
nelso419
08:09:11 06/30/17
I used a chemtool straw to poke in that hole and i felt
dTb
18:58:26 06/30/17
Heads are exactly the same as on a 95 (with VTC) (n/m)
ZXoltan
07:10:18 07/01/17
Re: New seals leaking?
nelso419
20:21:25 07/02/17
Glad you figured it out. (n/m)
Tanley (ATL)
08:04:41 07/03/17
