TwinTurbo.NET: Nissan 300ZX forum - The seals don't really see direct oil pressure
Tanley (ATL)
on June 29, 2017 at 1:46 PM
Re: Was there oil pooled in the timing cover?
posted by nelso419
on June 29, 2017 at 10:10 AM
just some crank case pressure. Wouldn't cause the seal to "seat". At least I wouldn't think so. Did you lube the seals with oil before installing?
New seals leaking?
nelso419
21:34:24 06/27/17
Did you check the gear itself?
Woody75 (Denver)
22:28:31 06/27/17
Re: Did you check the gear itself?
nelso419
07:58:10 06/28/17
Re: Re: Did you check the gear itself?
LitlElvis
11:30:52 06/28/17
Yeah I just tried mine, they're all solid
nelso419
11:56:23 06/28/17
nelso419
11:23:49 06/28/17
Tanley (ATL)
21:55:37 06/28/17
nelso419
10:10:14 06/29/17
The seals don't really see direct oil pressure -
Tanley (ATL)
13:46:32 06/29/17
Yeah I oiled them when installing. (n/m)
nelso419
18:29:44 06/29/17
Last thing I can think of is put it back together,
Tanley (ATL)
18:50:20 06/29/17
I had a similar problem a few days ago...
dTb
19:05:02 06/29/17
Is it the hole opposite the indexing pin for the gear?
nelso419
20:02:16 06/29/17
Oh ok. Not sure if that hole is there then...
dTb
21:02:22 06/29/17
Re: Oh ok. Not sure if that hole is there then...
nelso419
21:20:04 06/29/17
up to you. that puller is twice the cost of a seal and
dTb
22:03:44 06/29/17
I just pulled my seals and yes my 96 does have the holes
nelso419
08:09:11 06/30/17
I used a chemtool straw to poke in that hole and i felt
dTb
18:58:26 06/30/17
Heads are exactly the same as on a 95 (with VTC) (n/m)
ZXoltan
07:10:18 07/01/17
Re: New seals leaking?
nelso419
20:21:25 07/02/17
Glad you figured it out. (n/m)
Tanley (ATL)
08:04:41 07/03/17
