TwinTurbo.NET: Nissan 300ZX forum - Passenger window works from driver side but not passenger.
Subject Passenger window works from driver side but not passenger.
Posted by AudiSport44 on June 29, 2017 at 11:14 AM
  This message has been viewed 573 times.
Message I haven't posted here in probably a decade but I just picked up a Z32 TT, again. It's a 1993 if it makes a difference.
The issue I'm having is that the passenger side window seems to go up and down fine when operated from the master switch on the driver door only. When using the switch on the passenger side it seems to go down fine but it either doesn't want to come back up at all or come up at an excruciatingly slow rate.
I'm thinking the switch is bad since the motor works fine. That or maybe relay.
What do you guys think? Also what's a good place for a new switch?
Thanks!
Dan
