TwinTurbo.NET: Nissan 300ZX forum - 1st read twice look twice jack once. On a 2nd note >>
Subject 1st read twice look twice jack once. On a 2nd note >>
Posted by ZUL8TR on June 29, 2017 at 9:19 AM
  This message has been viewed 464 times.
In Reply To what the hell did i do to her? posted by Mad_Skids on June 28, 2017 at 11:17 PM
Message you need to fix the collapsed lines. Just to get you temporarily under way try to pull down the bent up cover and tubes, then gently squeeze some roundness into the tube so the fluid can move. That operation might break the tubes but it is a 1st try and worth a shot since replacement is the final fix.
First how big of a leak is it by puddle size and amount of oil you have to add and how often
As for your oil leak it is most likely the rear main seal that requires a tranny pull and once there the rear oil pan U seal can be done w/o pulling the pan, was done that way on my car.
ZUL8TR
