TwinTurbo.NET: Nissan 300ZX forum - Was there oil pooled in the timing cover?
Subject Was there oil pooled in the timing cover?
Posted by Tanley (ATL) on June 28, 2017 at 9:55 PM
  This message has been viewed 468 times.
In Reply To New seals leaking? posted by nelso419 on June 27, 2017 at 09:34 PM
Message With that much oil leaking, there should be a pretty obvious trail to follow. If it were one of the seals I would expect to see an oil stream from the bottom of the seal down the block to the bottom of the timing covers. Are you positive the leak was coming from underneath the timing covers? Did the timing belt have any oil on it?
