TwinTurbo.NET: Nissan 300ZX forum - Re: Egr bypass while motor still in
Subject Re: Egr bypass while motor still in
Posted by Placuch on June 28, 2017 at 12:33 PM
  This message has been viewed 490 times.
In Reply To Egr bypass while motor still in posted by Bigmatthew86 on June 26, 2017 at 05:20 PM
Message I was able to delete it all with just the plenum off. The worst part was undoing the nut that secures the pipe going into the driver side exhaust manifold. Couldn't do it with a line wrench because it was too short to have enough leverage. Regular open end didn't work either because of no room. I sawed off the pipe and finally got it with a socket. It is possible but I don't recommend it, such a pita. Unless your valve is causing you problems or you have the system leaking, I wouldn't touch it until you have to pull the engine.
