TwinTurbo.NET: Nissan 300ZX forum - Anyone hang two OEM fuel pumps on the stock hanger?
Subject Anyone hang two OEM fuel pumps on the stock hanger?
Posted by Zbullet on June 17, 2017 at 12:45 PM
  This message has been viewed 478 times.
Message I'm going to be going with a dual pump set up. It looks like the OEM run off the FPC Unit with a secondary running off a Hobbs switch is the best budget minded option. Running the second pump off a standalone ECU is obviously an option as well (I don't have Haltech in this Z).
I have a spare OEM pump on hand. A few questions:
1. Anyone know if two Stockers will fit on the hanger and down the hole?
2. It looks like the rubber insulator adds a fair amount to the diameter of the pump. Are these necessary? Most photos I see of the dual walbro setups are w/o rubber insulators.
3. My understanding is that the hobbs switch is boost activated. So I presume it'd have to go in the engine bay with a vacuum line to it which would mean running a signal wire back to a relay near the pump. Anyone know of any write ups for hobbs switch install on a Z32? I haven't come across any on the forums.
  • Anyone hang two OEM fuel pumps on the stock hanger? - Zbullet 12:45:36 06/17/17
