TwinTurbo.NET: Nissan 300ZX forum - Check the connector to the coolant temperature
Subject Check the connector to the coolant temperature
Posted by MixManMash on June 15, 2017 at 7:37 AM
  This message has been viewed 468 times.
In Reply To Re: how are injectors? posted by NoluckWill on June 14, 2017 at 08:41 PM
Message sensor for corrosion and clean it. Check continuity between this connector and the ECU connector.
It's likely corrosion or a break in the wire. I've had corrosion so bad in my old EFI harness that in some cases was 2 feet up the wire from the connector.
