TwinTurbo.NET: Nissan 300ZX forum - I used blue loctite on the 2 idler stud threads and red on
Subject I used blue loctite on the 2 idler stud threads and red on
Posted by jzack on June 12, 2017 at 3:33 PM
  This message has been viewed 530 times.
In Reply To Anti-seize or Loctite? posted by nelso419 on June 12, 2017 at 09:18 AM
Message final nut that keeps the pulleys in place. Figured with the red everything will be firm enough to remove the whole idler stud in the future even if just the 2 pulleys are in need of replacing.
LOL - given I put about 2k miles on the car per year it will probably be my future grandkids dealing with the issue (and they won't need a special tool)!!!
Believe I used blue on the VTC spring cover bolts too.
Also applied anti-seize to the crank sprocket gear since they usually rust to the shaft over time.
