TwinTurbo.NET: Nissan 300ZX forum - The solenoid valve that increases idle at cold start up is
Subject The solenoid valve that increases idle at cold start up is
Posted by jzack on June 07, 2017 at 9:35 PM
  This message has been viewed 649 times.
In Reply To Stalling (idle up?) AND Starting Problem ... posted by thumper300zx on June 07, 2017 at 03:00 PM
Message probably sticking...a common issue with age. It's the Air Regulator valve and its behind the balance tube about tube center. There are a number of posts about this issue.. some try spraying WD40 (do not use silicon) into the valve to unstick. Otherwise the valve gets replaced.
See this z1 web page - valve is at far right side. Runs $78 from them: https://www.z1motorsports.com/idle-air-system/nissan/300zx-complete-idle-air-control-package-new-p-6931.html
For the other issue...does car not crank when key is turned? There's a relay in the driver side wheel well that if going bad can result in multiple key turns to get a starter crank. There are posts on this and how-to's on replacing the relay (really easy too).
