TwinTurbo.NET: Nissan 300ZX forum - Auto to Manual ECU
Subject Auto to Manual ECU
Posted by TTwinZ on June 07, 2017 at 8:40 AM
  This message has been viewed 530 times.
Message This might be a dumb question, but when switching over your Automatic vehicle to a Manual transmission, should you have the ECU changed as well? Reason I ask is because I did the swap years back, I never did change my ECU. (I have an upgraded ash spec from what I remember). But i plan on doing a Motor swap over the winter with upgraded turbos so I assume to accommodate that I will need my ECU re programmed as well. And at that time would I describe my vehicle as a Manual (because that's what it is....Or an Automatic...because that's what it was?)
It's not what you buy, it's what you build!
