TwinTurbo.NET: Nissan 300ZX forum - Re: Testing fuel system for leaks
Pearl_TTZ
on June 05, 2017 at 9:02 PM
posted by JBrown
on June 03, 2017 at 09:26 AM
I mean, for starters, you should be submerging your rails under water and pressurizing fuel lines with compressed air to check for leaks first.
JBrown
09:26:47 06/03/17
Fuel pump should be coming on when you turn on the ignition
ZaXxon
10:48:04 06/03/17
Re: Fuel pump should be coming on when you turn on the ignition
JBrown
12:05:55 06/04/17
None of those. Check your fuses.
ZaXxon
16:45:28 06/05/17
Is your ECU connected? If not, it won't turn on the fuel
MixManMash
19:11:09 06/05/17
Re: Testing fuel system for leaks -
Pearl_TTZ
21:02:49 06/05/17
