TwinTurbo.NET: Nissan 300ZX forum - Are you still running PCV valves?
FrozTTy
on May 29, 2017 at 12:22 PM
Also tried another ecu with same EPROM, still dies when
posted by itsa300zx
on May 27, 2017 at 08:00 PM
Are they located or in stock locations?
I'd purchase new ones and check conditions of hoses etc.
How are your fuel related components (filter, fpr, etc.)?
wideband at idle goes from 13 to 15-16 then back to 13
Smokiedabear
13:10:36 05/23/17
Re: wideband at idle goes from 13 to 15-16 then back to 13
Cjw3
16:42:56 05/23/17
Idle is in Open Loop ......
zx299
01:19:53 05/24/17
That has been proven wrong.
Cjw3
06:49:14 05/24/17
Ah. Finaly someone came to their senses...
kickerzx
08:34:55 05/24/17
All I have is forum Conversations
Cjw3
09:43:11 05/24/17
Exelent. I always knew it was CL as nothing else really
kickerzx
14:33:20 05/24/17
Here is the Link..
Cjw3
20:51:23 05/24/17
Check that the PCV hardlines coming out of the intake valve
MixManMash
17:50:39 05/23/17
Re: Check that the PCV hardlines coming out of the intake valve
Cjw3
18:06:43 05/23/17
One other thing to check is the O2 sensors and
MixManMash
07:06:24 05/24/17
Here:
MixManMash
07:09:02 05/24/17
02 sensors makes sense
Smokiedabear
16:59:28 05/24/17
resetting throttle position switch looks to have fixed! thx! (n/m)
Smokiedabear
09:14:42 05/25/17
i have a question for tps reset...
itsa300zx
20:08:03 05/25/17
Nope. It can be running. When you unplug it, the RPM will
MixManMash
21:34:41 05/25/17
Re: Nope. It can be running. When you unplug it, the RPM will
itsa300zx
22:20:34 05/25/17
Sounds like something else going on if it just shuts off.
MixManMash
23:03:59 05/25/17
Thanks, I'll take a closer look at the IACV. (n/m)
itsa300zx
08:35:14 05/26/17
Is the adjustment screw all the way in? Even if the IACV
MixManMash
19:19:01 05/26/17
Idle screw is not all the way in, that's why I'm so confused
itsa300zx
00:30:24 05/27/17
Something really goofy is going on there.
MixManMash
08:38:57 05/27/17
Check your O2s. You may even want to try unplugging them to
MixManMash
08:41:59 05/27/17
Re: Check your O2s. You may even want to try unplugging them to
itsa300zx
15:29:13 05/27/17
itsa300zx
20:00:24 05/27/17
If the throttle bodies are dirty, that could be part of
MixManMash
08:36:20 05/28/17
Are you still running PCV valves? -
FrozTTy
12:22:23 05/29/17
Re: Are you still running PCV valves?
itsa300zx
14:51:51 05/29/17
