TwinTurbo.NET: Nissan 300ZX forum - Also tried another ecu with same EPROM, still dies when
Subject Also tried another ecu with same EPROM, still dies when
Posted by itsa300zx on May 27, 2017 at 8:00 PM
  This message has been viewed 562 times.
In Reply To Re: Check your O2s. You may even want to try unplugging them to posted by itsa300zx on May 27, 2017 at 03:29 PM
Message unplugging tps harness. Same with idle screw all the way out. If I hold the throttle slightly open and unplug it, I wants to die but I can keep it running by playing with the throttle. Going to clean throttle bodies next.
The car runs flawless, lots of power all the way to redline. This idle issue started last year, about a month before parked for the winter. I would like to get this solved before SZ tuning on June 22. Please help, I've tried the following:
Adjusted tps several times to the correct specs
Adjusted idle screws to higher idle 1200 rpm
Swapped ecu, coolant sensor, tps, iacv and air regulator
Any other ideas or thought are welcome.
Thanks,
Peter
