TwinTurbo.NET: Nissan 300ZX forum - i have a question for tps reset...
itsa300zx
on May 25, 2017 at 8:08 PM
Check that the PCV hardlines coming out of the intake valve
posted by MixManMash
on May 23, 2017 at 05:50 PM
Is the car supposed to shut off when you unplug the grey harness to the tps?
wideband at idle goes from 13 to 15-16 then back to 13
Smokiedabear
13:10:36 05/23/17
Re: wideband at idle goes from 13 to 15-16 then back to 13
Cjw3
16:42:56 05/23/17
Idle is in Open Loop ......
zx299
01:19:53 05/24/17
That has been proven wrong.
Cjw3
06:49:14 05/24/17
Ah. Finaly someone came to their senses...
kickerzx
08:34:55 05/24/17
All I have is forum Conversations
Cjw3
09:43:11 05/24/17
Exelent. I always knew it was CL as nothing else really
kickerzx
14:33:20 05/24/17
Here is the Link..
Cjw3
20:51:23 05/24/17
MixManMash
17:50:39 05/23/17
Re: Check that the PCV hardlines coming out of the intake valve
Cjw3
18:06:43 05/23/17
One other thing to check is the O2 sensors and
MixManMash
07:06:24 05/24/17
Here:
MixManMash
07:09:02 05/24/17
02 sensors makes sense
Smokiedabear
16:59:28 05/24/17
resetting throttle position switch looks to have fixed! thx! (n/m)
Smokiedabear
09:14:42 05/25/17
i have a question for tps reset... -
itsa300zx
20:08:03 05/25/17
Nope. It can be running. When you unplug it, the RPM will
MixManMash
21:34:41 05/25/17
Re: Nope. It can be running. When you unplug it, the RPM will
itsa300zx
22:20:34 05/25/17
Sounds like something else going on if it just shuts off.
MixManMash
23:03:59 05/25/17
Thanks, I'll take a closer look at the IACV. (n/m)
itsa300zx
08:35:14 05/26/17
Is the adjustment screw all the way in? Even if the IACV
MixManMash
19:19:01 05/26/17
Idle screw is not all the way in, that's why I'm so confused
itsa300zx
00:30:24 05/27/17
Something really goofy is going on there.
MixManMash
08:38:57 05/27/17
Check your O2s. You may even want to try unplugging them to
MixManMash
08:41:59 05/27/17
Re: Check your O2s. You may even want to try unplugging them to
itsa300zx
15:29:13 05/27/17
Also tried another ecu with same EPROM, still dies when
itsa300zx
20:00:24 05/27/17
If the throttle bodies are dirty, that could be part of
MixManMash
08:36:20 05/28/17
Are you still running PCV valves?
FrozTTy
12:22:23 05/29/17
Re: Are you still running PCV valves?
itsa300zx
14:51:51 05/29/17
