TwinTurbo.NET: Nissan 300ZX forum - 02 sensors makes sense
Subject 02 sensors makes sense
Posted by Smokiedabear on May 24, 2017 at 4:59 PM
  This message has been viewed 534 times.
In Reply To Here: posted by MixManMash on May 24, 2017 at 07:09 AM
Message down the road I'll put in oem ones.
I have new ones but I do not believe bosch oem.
As for tps I will try this reset
I did have a bad 02 sensor signal wire from a short. I ran a new wire (signal) from ecu to the 02 sensor. Hmm the wire I used was a maf signal wire, so it had 2 wires on it.. but I only used one I doubt that would matter I used high quality solder.
Also specialty Z said it was ok to run at 13-13.5 due to ethanol in fuel they tune for that. If the car goes to 14.6 or whatever they say it will definitely a slight miss at idle, when the z does go there it does develop that.
Anyway will definitely try these tricks thank you all!
