TwinTurbo.NET: Nissan 300ZX forum - Re: wideband at idle goes from 13 to 15-16 then back to 13
Subject Re: wideband at idle goes from 13 to 15-16 then back to 13
Posted by Cjw3 on May 23, 2017 at 4:42 PM
  This message has been viewed 544 times.
In Reply To wideband at idle goes from 13 to 15-16 then back to 13 posted by Smokiedabear on May 23, 2017 at 01:10 PM
Message 13-15 is the Idle Routine figuring if all is OK..
The Idle does not know if it's at 13 or 10.. it's the same input from the Narrow band O2 Sensor.. so the logic of the Idle Circuit is to Bump to 'Lean' to see how far it has to go to 'Lean' the mixture to finally see it on the O2 Sensor.
I don't know about your other problem..
Cj
