TwinTurbo.NET: Nissan 300ZX forum - One reason I started down the ethanol road. To raise
Subject One reason I started down the ethanol road. To raise
Posted by not4resaleZ on May 19, 2017 at 12:32 PM
  This message has been viewed 558 times.
In Reply To Oem knock control sucks posted by Stanky (BC) on May 19, 2017 at 01:36 AM
Message octane and eliminate knock. I did the resistor mod and started blending e85 with premium in 2010. Recently when I replaced the transmission I installed a new knock sensor and harness. If egr valve is not in the way, it can be done with engine in the car. A little tricky but I practiced how far back to reach with two fingers. Then with the sensor and bolt between two fingers, reached in and the bolt just dropped into the hole.
