TwinTurbo.NET: Nissan 300ZX forum - Calling all transmission gurus
Subject Calling all transmission gurus
Posted by Bigmatthew86 on May 13, 2017 at 10:21 AM
  This message has been viewed 490 times.
Message Some of yall might have seen my other post. I lost D & OD in my transmission last month. I've did a flush & new filter along with a transgo shift correction kit in hopes it would fix it, it did not. So now I'm at the point it's time to pull it. Car is a 94 na/auto that has a tt swap. I have the receipt for jdm engine & auto tranny but now I don't believe they even installed the tt auto tranny. The transmission has a drain plug & I thought the autos did not. However I order filter/gasket for the tt & had to go back & buy a na transmission gasket. So here's my question. I won't be installing a na transmission back. I know they both will install but the re4r03a is longer. I have the na rear so what drive shaft do I need? A tt auto one & piece them together? I also read you can put the na torque converter & flexplate in the tt transmission. That seems like you wouldn't be getting everything from the beefed up transmission but I don't know?
  • Calling all transmission gurus - Bigmatthew86 10:21:19 05/13/17
