TwinTurbo.NET: Nissan 300ZX forum - Re: The oem had these on it
Subject Re: The oem had these on it
Posted by nissubaru on May 10, 2017 at 1:38 PM
  This message has been viewed 551 times.
In Reply To The oem had these on it posted by OldSchoolTT on May 08, 2017 at 07:46 AM
Message Not sure on this one specifically since as I stated in my other reply I used Tokico's, but I don't see how this piece would not fit? I understand there's a slit on the original piece but why does that matter? The hole is round, the strut rod is round...yes there's a slit but we aren't using it?
I did see that on the Z1 shock absorber bushing kit they say "Owners installing KYB or other aftermarket shocks featuring a ROUND threaded shaft should select the KYB option." Not sure what that's all about though or what that changes.
Anyways I used the original cup that you are pointing out which should go over top of the dust boot and bump stop (see diagram below).
You can also see this cupping the bump stop here in this pic I found
