TwinTurbo.NET: Nissan 300ZX forum - I wonder if the block was decked and cylinder heads
Subject I wonder if the block was decked and cylinder heads
Posted by MixManMash on May 07, 2017 at 9:49 PM
  This message has been viewed 516 times.
In Reply To Timing belt not tight, tensioner at the end of slots? posted by Doug71zt(CAN) on May 07, 2017 at 09:26 PM
Message milled down significantly enough. What cylinder head gasket was used on the build? I would recommend measuring the heads and block as per the FSM to be sure.
Timing belt being installed correctly with the markings? Pointed forward as per mark?
The other thing to make sure is that the BDE instructions are being followed. I believe on many of the new intake cam gears, you need to use the new mark on not the old dimple.
