TwinTurbo.NET: Nissan 300ZX forum - Need help with headlights!!
Subject Need help with headlights!!
Posted by jj90zx on May 05, 2017 at 12:12 AM
  This message has been viewed 590 times.
Message Hello all,
I've got a weird headlight problem going on! So as it is, with just the low beams on the pass low beam works great. However, the pass high beam and both low and high beam drivers side lights are on (but very dim) also!! I've tried to swap relays and checked fuses. It seems like a ground problem maybe? When the high beams are on I believe just the pass side one works but the pass side low beam is also on but very dim, nothing on the drivers. I purchased this car as it is , looks like they might have done some "wiring modifications " to the headlight connectors. Any ideas? Thanks
