TwinTurbo.NET: Nissan 300ZX forum - PS turbo smoking?
Subject PS turbo smoking?
Posted by Doug71zt(CAN) on May 04, 2017 at 6:31 PM
  This message has been viewed 496 times.
In Reply To need help determining where oil is coming from posted by motivZ on May 04, 2017 at 02:37 PM
Message Usually you will see an oil leak in that area from the oil supply tube to the turbo that runs behind the manifold/turbo joint on the passenger side. Corrosion of the oil supply tube, especially the heat insulated foil covered later part number.
It can be replaced in situ, not a fun job though.
Otherwise, leak may be coming down the head from the exhaust valve cover or a cracked PCV hose and smoking on the manifold.
If you indeed have oil pushing out of the manifold/turbo joint at a gasket leak, you have a bigger issue than the smoke, your motor is throwing oil out the exhaust.
