TwinTurbo.NET: Nissan 300ZX forum - My car will not idle at 750
Subject My car will not idle at 750
Posted by JMartz on May 02, 2017 at 7:52 AM
  This message has been viewed 549 times.
Message The engine in my car has a high idle (around 950). This is a recurrent malfunction that I have corrected several times.
I recently replaced the ECU's coolant sensor and connector. A bad contact was causing improper temp values to be read by the ECU. The ECU has a table of idle speed vs temp and will only control the idle air control valve correctly within a narrow temp range. This brought down the idle to 750.
Idle rpm is back up to 950-1000. I am clear out of options. Timing and MAF voltage are correct. The resistance values of the IACV are within spec. Car has a smooth running engine with no misfires or hesitations. Don't suspect an air leak; but who knows.
Any ideas from the experts?
